| Thread Details Posted by diesel dan, this thread has received 86 replies and been viewed 6252 times. |
#1 |
Destroked
Anybody seen this video????
I just came across this video on streetfire.....I realize that lly's overheat, but I never dreamed it would be this bad. Not to count this idiot behind the wheel not stopping and at least doing something about it, or even letting the truck cool off. I just cant believe that someone would keep driving arrogantly just to prove a point.
And the idiot wonders why it went into limp mode.....http://videos.streetfire.net/categor...af013f4333.htm
'04.5 Chevy 2500HD LLY,Alli, CC, SB, 4x4, Sleeved, Braced, FASS, 4" SS Silverline exh, EGR Blocker, all thanks to MA, EFI Live tuning by me with V2 switched DSP5, 71mm Cheetah turbo, ARP Studs with "C" gaskets, Transgo Jr., 20x9 Diamo Karat 8's wrapped in Terra Grapplers, Superlift AAL in rear, some stainless........yeah it shines. 1985 Dodge Ram 50 Turbo Diesel, 5 Spd, 97k on the clock......daily driver 35 MPG
#2 |
TDG MAFIA MEMBER 48
WOW Not good
-Tom- Daily driver 2004.5 Dodge 3500 DRW 4X4 3.73 4 speed auto trans sitting on Cooper Discoverer H/T, Smarty, Quadzilla Boost Fooler, custom exhaust stacks plans for Trans Twins Injectors Then a new big :censored camper |
#3 |
tire burnin, smoke blowin
you guys look at the dash in the video- it says 70 mph and 3000rpm, smart ***** is towing in 4th instead of overdrive that could be a problem if you're towing near redline for a while in hot weather?
01 chevy 2500hd plowtruck- boss v plow, airflow stainless v box salter, 305 MTRs, k&n, ppe boost valve(32psi), and diamond eye 4"exhaust, amsoil remote dual oil filter kit(bmk17) 02 chevy 2500hd ccsb- RCD 6" lift, fabtech inner & outer tierods, cognito pitman & idler arm supports , k&n gen 2 intake w/afe pg7 filter, banks 4" exhaust, 315/75/16 BFG A/Ts on centerline rims, amsoil remote dual oil filter bypass kit(bmk17) nicktane billet filter head and 2 micron cat filter. edelbrock 1792 liftpump w/hobb switch, moonshine tuning (500+rwhp),lbz cp3, suncoast trans stage 4 w/1057 converter. 05 honda trx 450R quad - sand dune/wheelie machine, honda racing cam, snorkel, airbox and exhaust |
#4 |
Thats the infamous "Overheat video". I'm not exactly sure what the outcome of TxC's suit against GM was, even with that video.
#5 |
so is it just the lly that overheats like that, because the lumber yard were i use to work we would pull well over 26,000 with the lb7 and they never overheated, and thats in 90 degree wheather. we had a 2005 powerstroke that had 4 turbos go out but that is why i wouldn't get a new powerstroke.
#6 |
yeah some lly s do, knock on wood; my 2 lb7s have not overheated yet, and i have towed in 90* weather with no problems.
#7 |
Copy Cat Killer
So far I haven't had issues (knock on wood). I towed a ford dually to a few sled pulls on some HOT days this summer, but no problems:shrug:. If (when?) I start having issues I'm going to killerbee, I like his stuff.
Elite Diesel Engineering 04.5 LLY: Almost stock
#8 |
Yeah, its only the LLY's that seem to have a problem. I am not sure of the percentage, though.
Killerbee knows infinitely more about this subject than I do, though. |
#9 | |
- Steve 2004.5 2500HD CCSB, 4x4, D/A, tow tune, TD-EOC Goodies occupying space in garage: Corsa full exhaust, Isspro gauges, KB CAI 2006 Tahoe Transport 33WTB; 14,000 lbs. |
#10 | |
I beleive the point Chris is trying to demonstrate is that an LLY-equipped truck will not tow the manufacturer's claimed maximum load at legal speed limits under certain conditions. Some owners expect the truck should do so under any condition. Others, myself included, don't.
